Tail block too thick for pickup- fix
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=41807
Author:  Chris Ensor [ Thu Oct 31, 2013 8:32 am ]
Post subject:  Tail block too thick for pickup- fix
So I recently changed to a laminated tail block and low and behold, I made it too thick when I glued up the last batch. Not a big deal- unless you are installing a pick up. I remembered seeing Frank Ford (I think) sharpen the back of a forstner bit and using it to drill from the outside of the guitar. He used it to countersink the bolts on a bolt on neck. Well, I am not a machinist, so that wasn't an option for me. Instead I came up with this thing:
The shaft is a long 3/8" bolt with the head cut off. I cut a slot in the end to allow the bade to set down in it. The blade is an old piece of a bar clamp I took apart years ago. I sharpened it on opposite sides so that it would cut properly while spinning (think router bit). I also cut a slot in it to accept the bolt- this way the two pieces would be locked together. But just for security, I added some superglue gel. It was a wonderfully tight fit and held rock solid. The hole for the end pin jack had already bin drilled to the required 1/2", so I wrapped tape around the 3/8" shaft of the cutter until it was 1/2". This allowed the cutter to be perfectly in the center of the end pin jack hole. The only problem with the thing- it cut better than I expected and I almost cut too deep. laughing6-hehe
Problem solved. I hope this helps. I am sure I am not the only person who has done this.
Author:  ZekeM [ Thu Oct 31, 2013 9:00 am ]
Post subject:  Re: Tail block too thick for pickup- fix
That's essentially a homemade reverse counterbore (spot face). Very handy tools when you need them. Image
Author:  jfmckenna [ Thu Oct 31, 2013 9:07 am ]
Before I knew there was such a thing as a reverse forstner bit I took a spade bit and ground a blade into the opposite side and it worked like a charm. I still use them in fact for bolt on neck conversions or operations like you are doing.
Author:  Terence Kennedy [ Thu Oct 31, 2013 9:28 am ]
You can get reverse spotfacers and pilots at The Yard Store. Very clean cut.
http://www.yardstore.com/browse.cfm/4,5326.html
Author:  Chris Ensor [ Thu Oct 31, 2013 9:36 am ]
Nice. I never knew there was a reverse type bit available. I am totally happy with the one I made. And it was free- one of two my favorite four lettered f words (the other one is food).
Author:  Chris Pile [ Thu Oct 31, 2013 10:34 am ]
MAN! Spent a lot of time at The Yard Store when I was a kid.
Aircraft tools of all kinds there (natch!), just like this reverse spotfacer.
